Old Sep 14, 2012 | 06:12 PM
Billy22Bob's Avatar
Billy22Bob
Default Re: Killer Chiller - intercooling option
OK - to rejuvinate an old thread......
Kincaid had a burglary and are finally back on track for KC's
They have them for $750 with some discharge/recharge costs from your local AC shop.
".....We use a 70,000 BTU/hr, 28 plate exchanger, rated at 450 psi. The unit is made of 316-SS. The water side uses 3/4" 90 degree barbed fittings, and the A/C side uses #8 AN male fittings....We can knock $100.00 off of that, if you can get 5 or more to sign up...."
Key here is the discussion I want to get into.....
70,000BTU/hr (20kW/hr) is the quote.
However that is at odds with the capacity of the AC compressor we run. Hence why I would like to question if a larger AC compressor may also be required.
Steve - feel free to chime in - even tho you drive a P
b22b
