Old Sep 15, 2012 | 01:16 PM
turbomar's Avatar
turbomar
Default Re: Removing the head light assembly
REMOVAL
1. Disconnect the negative battery cable.
2. Remove the headlamp unit upper retaining bolts (1).
3. Open the access panel in the inner fender well.
4. Remove the lower headlamp unit retaining bolts (2).
5. Lift the headlamp unit from the front fascia and disconnect the harness connector and the front position lamp socket.
