Re: Removing the head light assembly
turbomar
REMOVAL
1. Disconnect the negative battery cable.
2. Remove the headlamp unit upper retaining bolts (1).
3. Open the access panel in the inner fender well.
4. Remove the lower headlamp unit retaining bolts (2).
5. Lift the headlamp unit from the front fascia and disconnect the harness connector and the front position lamp socket.
Removing the side marker light will also give some room to work in. I will add this .... eventho you may get the headlamp assembly loose and ready to lift out. It is extremley difficult to work it around so it comes out. Most people have had to remove the front bumper fascia to get it out.l Just sayin ...
