Old Sep 16, 2012 | 05:37 PM
speedfiend's Avatar
speedfiend
Default Re: Anyone DIY the front K-MAC kit?
The difference between the front and the back installation is that you have a bigger job getting the old bushes out. Therefore you need to remove the lower control arms and use a press to do that job with the removal tools that came with the kit.
The rest of the job is pretty straightforward, but an alignment will be necessary after it's done. Take the time to work with the aligner to establish different camber and caster settings and mark where the bolts will be sitting for them so you can do further adjustments without going to the aligner.
And do the bolts up TIGHT!
