yes - the last 24hr have convinced me the KC is simply an Add-on and no silver bullet.
I still haven convinced myself of the larger pump - higher flow idea - but the empricals are possibly there saying - decreasing the residence time in the IC is improving things....
But lets say it does....
So -
- larger IC (LET or whatever)
- 80deg Stat (hmm...or lock it open)
- High Flow Pump (Johnson or whatever)
- Coolant seperation
- Foil (baked potato) the Charge Air cooler - if you can form an air gap with air flow - even better
- Run low glycol ratio to increase cp
- KC to top it off with larger condensor and compressor if you got heaps of money/time.
- turn the cabin AC on when engine needs it and put the heater on (not sure if the AC is up or downstream of the cabin heater coils)
