Old Sep 21, 2012 | 04:18 AM
  #235 (permalink)
simkard's Avatar
simkard
Default Re: 74mm Throttle Body Upgrade
The elbow is OK, it fits the OD of both size throttle bodies as they are the same size outside except that the inside diameter of the 74mm throttle body is 74mm and the inside diameter of the 68mm throttle body is .......68mm. The O-ring is the same for both throttle bodies. The answers are all in that post.
Hi, thanks for your answers, but, after reading the whole post, i just couldn't find the 74mm MAF housing MB ref.
Could you please tell me which is the good ref for this part, i will try and look over the net to buy one for cheap.
Basically, i understood that the "Intake Manifold", "Elbow", "O'Ring" are the same diameters which are compatible with the "74mm Throttle Body".
But it seems that there is the MAF housing which is not good at all.
Hope you can help me to find the good way of doing the right mod with the right parts.
Thanks !
