Old Sep 21, 2012 | 10:36 AM
onehundred80
Default Re: new tire vibration info.
Originally Posted by Warren Smith
Hey, I guess I finally got an answer to my steering wheel shimmy problem. I bought new continental tires for the front of my 06 crossfire which I just purchased with only 6000 miles on it. The dealer who had the car since new had run over something and knocked the front end out of alignment. Anyway This is the fourth set of tires the tire dealer has put on the car. New wheel bearings and races where needlessly installed and the steering vibration damper was replaced. Come to find out after getting continental involved is that this is normal for that low profile tire. Vibration will occur at 35 mph to 45 mph until the tire has reached a certain temp.. However the tire dealer has agreed to send the car out to have the tires" road forced" balanced. Personally I don't think this will solve the problem either. I think that this is the nature of the belt that is used in the tire. Anyway I guess I can live with it since I know where the problem is. Everyone including continental has been very nice and has tried to get the problem solved. Just thought you might want to know.
Did Continental tell you this directly or did the tire dealer say that Continental said this? If the tire dealer told you I would not believe it. If a Continental rep told you then you should tell him that you will post that info so that nobody else purchased Continental tires unless they could put up with the shimmy.
