Hi!
I have some OEM SRT-6 parts for sale: (+ shipping cost)
1.) Front and Rear SRT-6 brake calipers with rotors and brake pads(Sorry dont have pictures). But they are in good condition.
600 USD
2.) OEM Garret intercooler(without the sensor), clean(no oil)l, perfectly good condition. MB: A112 500 00 00.
500 USD
3.) Throttle body 74mm, very good condition. MB: A113 141 01 25.
150 USD
4.) Y-pipe(without the sensor), very good condition. MB: A112 090 08 31.
100 USD
5.) 6 pieces of OEM Injectors. MB: A113 087 01 23.
150 USD
6.) Rear differential, good condition, no movement at all, MB: A210 353 15 01.
500 USD
7.) Fuel pump Pierburg, working perfectly. MB: A000 473 00 01, Pierburg nr: 7.21960.04.
75 USD
8.) Rear flex disc in usable condition. MB: A203 411 00 15.
30 USD
9.) Fuel rail. MB: A112 070 03 95.
100 USD
10.) PLX Kiwi + iMDF.
135 USD
PLX Kiwi Wifi + iMFD iPhone/iPod touch/iPad automotive interface
Kiwi Wifi + iMFD combines the best of both worlds into one product. Since the OBDII port does not offer all the sensors you may want to monitor, the added iMFD sensor support allows you to add up to 32 additional dedicated sensor modules from the PLX product line. This includes wideband Air/Fuel Ratio, Exhaust Gas Temperature, Fluid Temperatures and much more.
The added benefit of Kiwi Wifi + iMFD is that with every additional iMFD sensor module you add, your performance does not degrade. For example, if you're monitoring only 1 sensor from the OBDII port and your refresh rate is 5Hz, by monitoring 2 sensors, your refresh drops to 2.5Hz and so on. By adding 1 or 32 iMFD sensors, your refresh rate is always kept constant at 10Hz. This results in higher performance monitoring for even the most demanding applications.
Kiwi Wifi turns your iPhone in to a powerful automotive tool.
Kiwi Wifi Features Include:
* Check Engine Scan Tool
* MPG Gauges
* Engine Sensors
* Customizable Dashboard
* Real-time Dyno
* Data Logging
* GPS Track
* Skid Pad
