Re: 2005 SRT6 Electrical Problems - please help :)
Cal_Cobra
Infinity I'll check that. Was it your distribution block that you had to replace or ?
I called the Chrysler parts dept and they cannot find the part # for the voltage regulator.
Anyone have that in case I need that?
Thanks,
Brian
Looking around it may be less bother to change the whole alternator for a reman. The numbers below are Chrysler numbers and they will be expensive.
If the alternator is a Bosch (some have Valeo alternators) the part numbers are;
ALTERNATOR 05097756AA Bosch
*05127665AA REGULATOR, Bosch
*This number only appears on the 2004 parts list, the alternator part number is the same as the 2005 alternator for the SRT6.
Check the parts lists at the link below.
