onehundred80
Looking around it may be less bother to change the whole alternator for a reman. The numbers below are Chrysler numbers and they will be expensive.
If the alternator is a Bosch (some have Valeo alternators) the part numbers are;
ALTERNATOR 05097756AA Bosch
*05127665AA REGULATOR, Bosch
*This number only appears on the 2004 parts list, the alternator part number is the same as the 2005 alternator for the SRT6.
Check the parts lists at the link below.
It doesn't look too bad to swap the voltage regulator, but looks like I'll have to remove it so Chrysler can find the part# for it.
During my lunch break today I tested the distribution block from the battery and it's fine. I also thought I should check all the fuses. Oddly the only blown fuse goes to the "sound booster" (the stereo amp I suppose).
Thanks,
Brian
