Old Sep 25, 2012 | 10:30 AM
itsky's Avatar
itsky
Default Re: A couple of Tire Questions
Originally Posted by Spudracer
The car was aligned (by a dealer) when the Dunlops were installed. And this appears to be a pure alignment issue. So my questions are.....
  1. Is this sort of uneven front tire wear common on the SRT6?
  2. Is there anything particularly unusual or tricky to aligning this old Merc suspension?
  3. Do these SRT6's have trouble holding an alignment, camber or toe-in? Can't believe caster has anything to do with this.
1. If the wheels are out of alignment, you will see the wear. I had this issue on my old N/A convertible, but went away after a proper alignment.
2. Shouldn't be, but you will need to find a shop that has the proper equipment from my experiences.
3. Do you have stock suspension parts? How many total miles on the car?
