Old Sep 26, 2012 | 04:11 PM
turbomar's Avatar
turbomar
Default Re: Bad vibration after flex disc swap.
Can you rule out rear drive shaft misalignment? Both drive shafts should be in almost perfect alignment. The disks won't perform well at more than 1 degree angle. I'm guessing you are getting the vibration now cuz the new disc is stiffer and has less give than the old one
