Re: dip stick vs. level sensor
8 quarts here with NO usage in between changes. If I were you, I'd add a little, check, if needed add a little more, check and so forth and so on. If your loosing a quart I hope it's leaking on the ground and not seeping into the combustion chambers.
Les
