Old Sep 28, 2012 | 07:17 PM
waldig's Avatar
waldig
Talking Re: Faulty ac expansion valve?
If you have fixed the valve twice, its not the issue. YOu have not given pressures _YET.
If your going out on high head, decrease,reduce, remove some of the charge. Are you charging by weight after evacuation?????????? Add less charge, dont fall for the label, it might not be accurate - at least you can add less charge and go from there. Clean the radiator coil as suggested also..
Woody
