velociabstract
Your fine on the inside and outside. The only place you'll rub is in the rear fender liner which has room to give. You wont hurt anything and it'll only rub in situations like turning sharply while backing up. Nothing will break and it won't hurt the tire. If it drives you crazy, pull the wheel, loosen the fender liner, heat it with a heat gun, bow it out of the way and tighten it back down. The screws that hold the liner onto the fender lip will be close but will clear. According to me.
Les
That's all I need to know then, thank you o'wise one! Now onto the rear to do new sway bushings.
