Old Sep 29, 2012 | 01:42 PM
turbomar's Avatar
turbomar
Default Re: Bad vibration after flex disc swap.
U might be right about inferior quality. I just recalled that when I replaced my disc, the bolts weren't quiet the same length. Check your bolts. Using a caliper and a kitchen scale, I ground the differences. It's real easy to loosen the hanger bearing and move it so the shaft is in a better alignment. Doing these two tasks will reduce vibration, seriously
