Old Oct 1, 2012 | 05:54 PM
SRT6_Roadster's Avatar
SRT6_Roadster
Default Re: Rear cat and Resenator delete and X pipe swap
I deleted the resonator and the secondary cats. As you said sounds great a full throttle but too much drone at normal highway speeds. I did not remove the h-pipe but did add an x-pipe into the mix. Still too much drone for me in the critical RPM range. If you can cruise at 80ish on the interstate you are golden. Otherwise the drone becomes annoying.
