Old Oct 2, 2012 | 06:40 PM
onehundred80
Default Re: Faulty ac expansion valve?
Originally Posted by scott
Still haven't solved the problem. I've replaced the pressure relief valve; I have purged the system and replaced the freon; I removed the grill and cleaned the condenser. The compressor comes on as it should. Checking pressure the low side pressure is 120, the high side is 400. After running for approximately 2-3 minutes the compressor shuts off.
Can you guys think of anything else I should try?
I think it is time to check the sensors in the system, I know squat about it but maybe the compressor is getting a signal at the wrong time, or an erroneous signal. Get the multimeter out and start checking the circuits. See the repair manual.
