Re: Brake booster vac line...killin' me.
you squeeze the tabs and slide the tube in until it locks in place.
something we did on grips car to get more room without trimming the y pipe is to switch the t/b rubber plate on the xfire to the flat gasket that the slk32 has. gives you the thickness of the plate closer to the s/c and away from the firewall
