Used Johnson CM30 (approx. 4,300 mi. on it)
Selling this lightly used Johnson CM30 (P/N CM30P7-1). I installed it last fall to replace my failing Bosch OEM unit. Since then, I have decided not to do the split-cooling system mod and don't want to put any additional undue pressure on the IC by using the higher flow Johnson pump. Yesterday I replaced the Johnson with a new Bosch unit. I keep records of all of my modifications with mileage, so I know this Johnson pump was put on November 26, 2011, and since then I have put approximately 4,300 mi on my vehicle.
So you know what you are getting here. The pump is in good working order and was running just fine when I removed it. I also don't drive the car that hard (no where around Northern VA to do it), so it is not like in that 4,300 miles the IC pump was getting excessive use. Actually, I would say the opposite, it was probably getting under average use.
Looking for a best offer and you pay shipping (probably USPS since that is most convenient for me).
This part sells new on ebay for around $150.
