Old Oct 17, 2012 | 11:06 AM
closer9's Avatar
closer9
Default Re: Question for those who have changed rear wheel bearing
Thanks for the info. Didn't get my bearings ordered. Someone bought just one of the two amazon had. So, waiting till they get more in stock. I can get them for the same price from rockauto, but they don't have the flange nut, and if I order the nut and bearing at the same time from amazon there is no shipping. Sucks being cheap. Especially since Autozone stocks the Timken bearing, but wants another $20 ea. AutohausAZ sells the nut cheap, but no Timken bearings, and shipping for two flange nuts is $15. Guess I might go ahead and do front brakes this weekend instead, since I won't be able to get bearings by then.
So, did you just use a chisel or something to crimp the side of the nut once you had it torqued? I'll have to take a look at the alignment settings. I was hoping I could just mark where everything was, and put it back that way. Is it toe that you set back there and not camber?
Guess, I'll have to find a socket too. Don't think I have any 12pts that large.
