Old Oct 20, 2012 | 12:03 PM
Buck Spunni's Avatar
Buck Spunni
Default Re: SRT springs on N/A?
Originally Posted by Beaner
-Yes
- ~¾" Depending if you want to change the spring pads also. which also depends on what your car has installed already. My NON SRT6 has srt6 springs installed. Not cut just installed and yes it did lower it and a firmer ride.
Doesn't your car have a heavier engine?
Sounds like SRT springs might be a option for me - .75" to an inch in front is great & the rear I may be able to adjust with thinner pads, or cutting 1/2 a coil.
I'd assume the stiffer springs would at least maintain load bearing if not even make it better?
Any comments on overall ride quality?
