smokey847
Had a tail/brake light out so I replaced both of them with two 45 SMD red dual-intensity LEDs. They give a great, bright, crisp glow compared to the halogens. Of course, they are causing the light-out indicator to glow so I bough two 6 ohm load resistors to trick the computer. The problem is I cannot figure out which wires to connect them to. The tail/brake lights have three wires coming from them: red, green and black. I have tried the load resistors on all combinations of the three and still have the light-out indicator.
What's going on? Does anyone know specifically which is the "hot" wire and which is the ground (these are the two the resistor is supposed to connect to)? Thanks.
