Old Oct 22, 2012 | 03:56 PM
onehundred80
Default Re: Oil Flush and tomorrow + level sensor + condition of oil pump?...
Originally Posted by Billy22Bob
Well I tried to get that damn oil pump out. Even bought an elbowed socket....but alas - no go.
It appears I need a "shorter" more compact socket to get the job done....see attach.
And of course you can buy them .....30 Euros, but I couldnt find a picture.
I'm also not sure - if you actually did find one - how you would get a true torque reading one.
I have confirmed though - the oil level sensor problem is fixed!!
Is there a way to reset it once replaced - so the ECU can restart/redo its calculations on oil change interval? WIS doesnt mention anything.
Note to self - check valve pn = 112589001000
I would guess that you set the ECU just like normal. not this part which just gives readings.
