Re: This Forum!
Its probably the fuel pump by the way. Buy the whole sender assembly/pump from a dealer, aftermarket can be real hit or miss and you don't want to drop the tank more than you have to.
These are notorious for pumps failing, same pump they have been using since the early 90's (with only slight changes made, mostly visual).
