Old Oct 23, 2012 | 01:57 PM
amx1397
Default Re: Sprint Boosters actual performance increase
being that the Sprint booster, increases the voltage to the gas petal. I'll explain that in a minute, but yes on the street regular driving. It's a blast. Even with my V8, it was fun.
It increases the voltage, so when you press the gas pedal 25% of its movement,,The increased voltage will signal the throttle body to 50%. And that goes all the way up to about 90 if you press it 90% you automatically get hundred percent. If you press it 75%, you'll get about 95%. So on the street at 10%, 15% of the gas petal. You're getting 30 to 40% reading on the gas pedal to the throttle body, so your car takes off faster ( on the track it wide open throttle. It does not)
I had one when my car was a v6. I had one when my car was a v8 the only reason I sold it is because with the V-8, you have to disconnect it to run on the dyno.. So I took it off. One time I just left it off and then sold it I hope this information helps you,,, Jim
