Old Oct 23, 2012 | 02:03 PM
  #44 (permalink)
onehundred80
Default Re: Help! My Crossfire Roadster won't start!
Originally Posted by turkeyman
This is just a thought. I had my lawn mower start then stop running. I was told to change to a new gas. After new fuel it was fine. Gas now does not have lead, which helped keep it longer. You may have filled at a station with old gas. To all owners if you are going to store your Crossfire for long periods, put Fuel Stabilizer into the gas tank for the amount needed per gallon of fuel.
Always run the car for a few min to fill the fuel llnes as well.
I used 20+ year old gas in my whipper snipper that had sat around since the late eighties. It was a two stroke mixture from an old outboard motor, it worked fine. I finally used it all up this year.
My old Mustang has a half tank of leaded fuel in it and it ran just fine twenty five years after the tank had been filled, if I put it back together today I'm sure it would still run thirty five years after the tank had been filled.
Maybe this old gas lacks some of its original volatility, but it still works.
If you have old gas, send it to me.
