Old Oct 24, 2012 | 03:50 PM
cudaman's Avatar
cudaman
Default Re: 62mm pulley: fuel system OK?
Originally Posted by Billy22Bob
All I can add are - Steve's thoughts....
https://www.crossfireforum.org/forum...tml#post645557
oh and of course.....take it or leave it.....my calcs suggest you need 580cc to maintain at least 12AFR at 6200rpm and 800cfm (62mm pulley+ supercooler)....550cc without a cooler...(ie: 36F hotter= 6% less density/power)
But as you quite rightly pointed out and in line with Steve's logs....my cfm and cc's may be 5-10% high...but that's not such a bad thing though when designing.
Isn't 12+ AFR sort of "risky"?.... Staying in 11's I would think would be much prefereble, especially at WOT. If going 12, should measure knock retard too. Aeroforce Scangauge can monitor two parameters at once on a single gauge if you are going to push it. Better safe than sorry. XFire engines I am sure are not cheap to rebuild.
