Old Oct 27, 2012 | 06:59 PM
Warren Smith's Avatar
Warren Smith
Default Re: Almost lost my F
Maxci chon is correct . Get 3M double- sided tape at any auto store. Remove the cover and put one side on the back of the letter and then trim with a exacto knife. Then take off the other cover on the reverse side and place the letter in position. Make sure you get it where you want it before you press it firmly in place. If you screw up you will probably have to use a heat gun to remove it.
