Old Oct 28, 2012 | 06:57 PM
onehundred80
Default Re: gas tank capacity srt-6
Originally Posted by arado
Mine hold 12 gallons at warning light. gary
From an old post of mine
I was running low on gas last night and as I approached the gas station to fill up the low fuel lamp came on.
It took exactly 50 liters, which more or less confirmed that the tank holds 60 liters total, leaving me with 10 liters reserve rather than the 8 liters stated in the Owners Manual.
50 liters = 13.2 US gallon = 11 Imperial gallon.
60 liters = 15.8 US gallon = 13.2 Imperial gallon.
So the reserve can be safely said to be about 2 gallons (8 liters)
FLUID CAPACITIES
Metric U.S.
Fuel (Approximate) 60.0 Liters 15.8 Gallons
Fuel Tank Reserve 8.0 Liters 2.1 Gallons
Engine Oil (with filter)
3.2 L Supercharged Engine 8.0 Liters 8.5 Qts.
Cooling System *
3.2 L Supercharged Engine 14.5 Liters 15.3 Qts.
Automatic Transmission 8.0 Liters 8.5 Qts.
Rear Axle 1.3 Liters 1.4 Qts.
Power Steering Reservoir 1.0 Liters 1.1 Qts.
Brake Reservoir .5 Liters .5 Qts.
Windshield Washer Reservoir 7.0 Liters 7.4 Qts.
* Includes heater and coolant recovery bottle filled to MAX level.
