I am looking for an argument
Oct 29, 2012 | 04:16 PM
permalink
waldig
Feb 2008
4,508
34
VA
Re: Iam looking for an argument
180, note the inlet and outlet are are at opposite diagonal corners. I have a solution to the flow rates balance issue.
The 1/9th restriction would promote more flow and 2: 1 is a good estimate, I concur with you on that one.
With Twice the flow and greater temperature differentials, it feels like this could be better than factory cooling, I.E. lower IATs. [ given the massive increase in pump and h/e sizes].
The path restriction-friction would be 1/9 the stock restriction and about 3 times the cross section and maybe twice the flow, should be non turbulent due to the lower rate of flow per channel. BAD MATH WARNING; 2x flow, divided among 3x tubes =about 2/3 rate of flow or 3/2 as much latency time = = better heat up take.
I really dont want laminar flow, need to scrub off the boundry layer / film layer. Rather be in the goldie locks region somewhere in the middle.
OVER.
waldig
View Public Profile
Send a private message to waldig
Find all posts by waldig
