Old Oct 30, 2012 | 08:32 PM
  #104 (permalink)
Hawk Monster's Avatar
Hawk Monster
Default Re: How to program your own key. SAVE $$$
OK The programming ONLY works if you have a mew key. Try the battery and let it stay off for a couple of minutes. You may jear the alarm go off so don't be concerned. If that does NOT work, the module that controls that is in the trunk on the right side under the floor. Check that for water/condensation or a loose connection.
Do you have a repair manual if NOT there is one on line? keep us posted on the vattery issue.
One more thing -- Change the bateries in the FOB before you do the battery trick.
