Old Nov 1, 2012 | 10:22 AM
ala_xfire
Default Re: Which sensor is this?
The relays are all the same, they have the same number stamped on them, #5706. The fuse is bigger, it is #5 and it is 40amp.
Dave, you are both correct, and incorrect.
I was going by memory from when I examined the RCM that rayth sent me ( that I forwarded on to tighed1 ).
I wrote all the relay numbers down from that one, and it did in fact have a 5708 relay in the air pump location, while all the others were 5706 like you stated.
I just went out and removed my RCM, and you are correct there, they ALL are 5706.
BTW, did anyone ever figure out if we could order & replace these relays ?
