Hello everyone,I have an '05 roadster with 43,000 miles on it. The story about the Skreem module is scaring me. Does it have anything to do with the amount of milage on the car? The only problem I've had was two weeks ago I went to the beach about an hours drive with the top down, it was about 90 degrees outside, went to put the top up and it just beeped at me, lights for top, air foil, and traction control all lite up. Turned off the car, started it up 3 times and everthing worked no problem since, has this happened to anyone else? I had Auto Zone do a battery check, starter check and alternator check, everything good. What should I be keeping an eye on? BTW you guys are great, I have fixed many little annoying problems with the advice on this forum. I am in Tampa Fl also. Thanks for any help.Gary
