h82bL8.53
alexfire
Sorry been away from the computer. No I didnt have them check that code. I suppose they would know what that code means, I'll go back and have them check it. I'm not sure what that code means, can you enlighten me? And no the check engine light didn't come on. After starting it 3 different times everything worked and is still working.
The 'DTC' codes are malfunction codes stored in memory, a scanner is required to retrieve / reset them. You can have codes that point to a past problem without having the CEL ( check engine light ) come on ( or it may have come on and gone back off without you noticing it )
Look in the helpful links for a list of known codes.
https://www.crossfireforum.org/forum...sfire-dtcs.pdf )
