Old Nov 8, 2012 | 12:37 PM
magredvet's Avatar
magredvet
Default Re: expecting the worst - lean AFR
Originally Posted by JesseJamessrt6
Great feedback guys, thanks. I am only starting out with a 62mm SC pulley with DCAI. Magredvet, did you have a lean issue with the 181? If I plan on going stacked one day would it hurt to invest in the TTM setup or will this run too rich?
Without the upgraded fuel system, I was going dreadfully lean above 5000 rpm, at one point it even threw a lean misfire code..............that's why I decided to go the whole hog, and fit the Zt2, so I could monitor the AFR all the time.
OT ...........where in South Texas are you located ?
