FUBU
So what is best 200, 220 or 250uF capacitor?
Also, is there a possibility to make that 40 is not the maximum level? I.e. when using itrip from an iphone the volume is not that high. would like to crank up about 10 more clicks.
FUBU - it's all personal preference on how loud you play your music, the style of music, settings of your equalizer (if you have one) and if you've changed any components (head unit, amp, speakers). I would suggest you use some blade connectors on your car wiring and capacitor leads so you can swap capacitors until you find the right sound without having to cut wires.
As far as your volume coming from your iPhone, have you turned up the media volume on your phone? Just a thought.
RL
