Old Nov 10, 2012 | 06:25 PM
onehundred80
Default Re: Electric Window Blowing 40amp Fuse!
Originally Posted by Albert L. Murphree
Every time I try to roll down the right side window, it blows the 40amp fuse. I replaced the motor 1.5 years ago (By Dealer) it stopped the problem for a little while. Now it is doing it again! I am being told it is the Body Control Module? I dosconnected the window motor and ran it off a seperate circutt with 11 amp fuse and it did fine! When I connect it back the the wiring harness POW! it pops the fuse. The antitheift is not working either. Dealer wants $ 2,400.00 to replace the BCM! Any thoughts?
I'd have a look at the switch. Automotive switches are made like crap.
Start at the cheap end of the fix and work your way toward the BCM. Then start at the motor and work back to the BCM. There's probably a short somewhere.
