Originally Posted by BullFrog
Your TPM didn't need recalibration. If the light came on and everything was fine, then you had a faulty sensor in one of the tires. Why don't you go and ask the service tech how he would go about recalibrating a TPM and see what response he gives you.
The tech did recalibrate the tps!
If I had a faulty sensor then it would not be possible to recalibrate.
Original Symptom:
The light did not go out regardless of what psi I had in tires.
The tech recalibrated and no more light. Basically resetting the tps.
