Re: What happens when you wash an Intercooler ?? Eh Bunkey?
I'm not sure if it's too late for Woody's unit, but one simple (but slightly time consuming) mod if you have the cooler out for a clean would be to dremmel burnish the inlets and outlets of each of the little capillaries so that they arent a flat sharp entrance, but rather a rounded face facing the incoming/outgoing air - we call this in the business the "kv loss factor" and has a marked improvement on entrance and discharge losses.
It wont improve cooling but it will reduce dP (pressure drop) a little.
Post Script - after analysis resulting in the later post - this will only hlep water dP, not air dP
