Old Nov 13, 2012 | 02:30 PM
onehundred80
Default Re: Specs on the stock SRT-6 rotors
Originally Posted by xman03
Does anybody know where I can find the specs on the factory SRT-6 front rotors? I just had my car state inspected and the shop claims that they are under the minimum width with both sides coming in at 1.151 where as the minimum is 1.60. They do not appear to have ever been machined so I'm just wondering if this is what they should be at or are they really worn. If I do have to replace them I'm either thinking of going with OEM or PowerSlot slotted like the ones listed on NS. Could you recommend the cheapest source for either OEM or PowerSlot as well as the pads.
They have been machined and they are below the thickness that they can be machined again, which is 1.16 not 1.60 as you typed.
Below are the specifications for the front and rear brakes for the NA and SRT.
Brake Specifications
Last edited by onehundred80; Nov 13, 2012 at 03:31 PM. Reason: Finally figured out how to get this info on here nicely.
