Old Nov 14, 2012 | 01:05 AM
  #98 (permalink)
BenzFire's Avatar
BenzFire
Default Re: A potential nightmare averted… thank you Crossfire Forum! Crankshaft Position Sen
1- Lindalu, let us know how it all went for you after the repairs are done.
2 - JonnyB0ii, It is normal for a Camshaft sensor to have oil on it .. and I've also seen many CPS's with oil on them as well, as far as I know it is normal for the CPS to have some oil on it as well since its inside the engine block. Now that you've changed the sensor with a good Bosch one you should not have the same problems but if the same problems return, try the fuel pump and test your coils also change CPS.
