Re: New Intercooler Core anyone? OH YEAH, IT JUST GOT REAL!!!
Well were on the page on the single pass design concept and I have been testing that approach. I believe in the highest differential between the inlet water and the engines hot - boosted air. I calculating the air to be about 240 degrees under full boost. With the cold water going across the entire core should extract the greatest amount of heat, especially since many of us are running the Needswings supercooler, an enhanced HE cores.
I hope to do a comparative test between the stock core and a parallel ( single ) pass flow design showing the relative restriction in an actual water circuit. This test will show the full circuit, pump - HE - IC - and all interconnecting hose restrictions. Yippie
Enjoy Woody
Weekend
