Thread: Rust
Old Nov 18, 2012 | 01:28 PM
The bodyman's Avatar
The bodyman
Default Re: Rust
This was a problem of the past. But some rear wheel arches still suffer. Its were the rear wing is spot welded to the inner wheel arch. Rust can start up between the joint there and rust bubbling appears on the surface of arch flange. Get your bodyshop to clean it up, spray it and get on top of it. Then check it from time to time to make sure its not coming back because it may.
Good luck
Jon
