Old Nov 30, 2012 | 05:26 PM
sk8erjosh09's Avatar
sk8erjosh09
Default Re: Turbo-New ideas & input
Originally Posted by bjames
I'm hoping my existing fuel pump will handle it, if somebody knows the flow rate it would help. I think the SRT injectors will handle the fuel at that end. I know the PSI of the fuel pump but I don't know the flow rate. I'm going for a small amount of boost. . I 'm not trying to reach SRT horsepower , I believe more boost ,more problems. I'll leave the higher boost up to the Hot roders.
Maybe someone with the knowledge can chime in on the fuel rate?
I'm also concerned about the beer flow rate it is going to take to keep my Fabricator productive.
SRT injectors will be fine Im sure. Low boost and you should be fine too. I'm very interested in your build it will help alot with mine (I get to see what breaks yours first ) . I have been researching the Crossfire parts collection for an insane amount of time to find every little difference I can between the NA and SRT. What is stronger, what is weaker... If you end up going higher boost I know exactly what you need to build your valvetrain up to spec lol. That's as far as I have gotten so far as sourcing parts is a PITA.
