Old Dec 2, 2012 | 08:49 AM
oledoc2u
Default Re: Rough Idle and Limp Power
Originally Posted by waldig
You could have a vacuum leak on the bottom of the throttle body, the base cracks the rubber and does this too. Woody Enjoy
Wouldn't that cause a rough idle all the time rather than intermittant Woody? Crank Shaft Position sensors go bad in other cars as well. I just replaced one in the Tahoe. They just wear out. If a vacuum leak, like a hose off, or lose air intake, that problem would be constant I would think. And replacing a part before it goes bad isn't wasting money, it's called preventive maintenance. 25K and up would be good preventive maintenance...keep the old one as a spare...
