Re: Fixed oil leak, but gave up on wheel bearings...
Well, after a little more reading, it sounds like I was almost there. Just need to push a little harder to get the axle out of the flange. Maybe spray a little WD40 in there and let it sit. Then the flange presses out of the bearing ID, and bearing presses out of the hub. Guess, I will try again when I have some time. Unless someone can tell me otherwise.
