Old Dec 7, 2012 | 08:05 PM
closer9's Avatar
closer9
Default Re: check your flex disks!!
There is no need to drop the diff. Loosen the carrier and the rear shaft slides forward. On the front the shaft will collapse enough to swap the disc. Yes replace both. They should be the same.
