Billy22Bob
Thanks
What does "all heat exchangers removed" mean?.....Am I recalling correctly you have a couple in the front on each side and you have them disabled (out of circuit)?
If can comment pls...
amx1397
tomorrow I go to the track the temp at track is going to be 80 to 81 degrees,, I will do some logs and let you know. I should leave the line afterburn out with about 60* f will see what the Iat's will be at the end of the 1/4 mile run jim
Can't wait...
Install notes/tips/tricks - more than welcome
b22b
