Sounds simple. Thanks! I'll post pictures when I get around to installing the system. Right now my xfire is on a boat.
grip grip
I would:
- use a voltmeter to see which wire is 12V when the switch is turned on and no voltage when off
- run a wire from the wire above to trigger a relay
- the relay will send 12V to the heater when it receives the signal
